Progress has been SLLLLLOOOOOOOWWWWW recently, but I finished up some more of the graphics and got them installed. I still need to make a USCG "anchor" emblem for the red stripe on the nose - it is screaming for a little more detail up front like that. The battery tray is also finally in, along with the BEC to power the 6 servos. My receiver is a 6 channel FrSky using all 6 channels:
Throttle
Ailerons
Elevator
Rudder/steering
Wing gear retract servo
Nose gear retract servo
The wing and nose gear retracts are on different servos since the wing is removable. The servo for the wing gear stays with the wing and the nose gear's servo stays in the fuselage. This helped avoid a much more complicated build, and also allowed me to adjust the nose gear separate from the wing gear, and those mechanical retracts can be touchy!
The canopy doesn't have the "window" decals added yet as I plan on sanding the canopy down a bit for a better shape. I really don't like the final shape on this one, and I've spent too much time making this bird to be unhappy with a major detail like that. So other than the canopy, it's pretty much ready for final testing. I need to make sure it's got enough power with the current motor, and will upgrade it if necessary. The maiden is in sight!
