Booms 2.0
Yesterday went out flying with two friends, we had three Mini Guineas and some other park flyers. I also had the Sea Duck with me, she was flying great! One of the other MGs was using 6*4.5 props and the other was on 6*3 and the SD was flying loops around them, almost literally. I even took her up to about 200ft and just completely cut the throttle, it has a very good glide ratio and I was rather impressed with how good it floated back down. About that time I started to notice that the left with seemed to be a bit bent. Turns out that the wing was bending upward a little just outboard of the boom. It was still handling great though. I have decided to remake the wing/booms/tails.
Tonight I redesigned the booms a little, made the part forward of the wind taller to come down to the bottom of the wing. This is what the first version looked like.
I also remeasured the the wing trailing edge angle where the boom should lay on the wing. This is what it looked like on the first version, less than perfect fit for sure.
The other thing I did was tapper the lower side, as well as the inner wall to meet at a closer point on the aft end.
Here are the plans I came up with, then the foam cut. I also taped the back side of the foam before cutting it, last time I taped it all up after it was built and that was a pain.
And here are the two 80-90% finished booms, the tops are not glued down yet. I am considering running the rudder pushrod internally.
With the deeper front end I have a larger ESC cooling air inlet. I haven't experienced any issues yet, but this should help anyways.
Next up is stripping the servos, ESCs and wiring from the old wing then building another wing. I am also going to replace the JST y-harness I had used with some 16 gauge stranded wire in a new y-harness.
