My 3D foam board plane has a single aileron servo mounted on the center line, with control rods going out to the aileron horns at an angle. It’s a common setup, but one I can’t get to work right as the ailerons are pulled up more than they are pushed down.
I get about 30 degrees up aileron, and about 20 degrees down. And yes, I start with the servo centered and aileron level.
I’m assuming that this is due to the angle of the control rod. And that the greater the angle, the greater the inequality. But, since I can’t reduce the angle, what can I do?
Attached is a photo of a similar plane.
