I have sized them for many different reasons. I don't think there is a one-size-fits-all rule that applies here (pun very much intended).
When I asked the question, I was sure your statement is correct. I can see that many of the FT designs are based on the 30" DTFB. They're ~14xx mm total. Just enough to account for any edge damage on the DTFB. Me... if the board isn't perfect in DT... it doesn't come home. I use the edges as a cut line.
I agree that even considering these factors, many of the FT designs are not optimized for minimal sheet usage. When I cut my planes I usually rearrange the pieces to get the most out of each sheet of foam.
It may be tough to see, one wing is already cut out, but I only print and cut out one wing template. And again... its an efficiency thing... not a penny pinching thing.
I also can imagine that for Flight Test selling kits, they have a different set of criteria. They want to make sure that any slight shipping damage doesn't result in a customer having a bent corner that is in a part. And that makes sense for all of their planes I've looked at. Then there is this one, that I failed to rationalize a reason.
With critical placement, even this design can
almost fit on one sheet. The little red portions are on the lower skin and not even visible. I don't know what affect they'd have on the flying characteristics if they were missing. If you are making one with the center pod by "
REMOVE FOR OPTIONAL ELECTRONICS POD" you could squeeze the pieces together and get them fully on one sheet. The only thing missing is the spar. If you've even built one other plane you probably have enough foam board in a bin to fit the spare on... this becomes a one board plane with no size adjustment.
The point I'm reaching for wasn't so much trying cram this into one sheet, but why they didn't upscale the plane and use more of the two sheets. And...
No race classes or anything; just a lot of TLAR (That Looks About Right) engineering based on material size, motor selections, etc.
I believe the Arrow specifically was developed to be small enough to carry around on a backpack like other FPV quads were while still being large enough to carry the FPV equipment of the day and fly well.
... makes a lot of sense. Re-watching Josh's video, he mentioned racing. And I know those are usually very well defined what you can and can't do. I was suspecting that it was a race class
hard specification
