So I recently purchased a Bonsai from HK. The suggested motor was out of stock and because I live within driving distance to the USA warehouse, I wanted to get everything from there. I think I got a suitable set up;
TURNIGY Plush 12amp (2A BEC) BESC
C1826 Micro brushless Outrunner 2400kv
Turnigy nano-tech 460mah 2S 25~40C
5x3 props
Turnigy 1440A Servos
AR400 Spektrum Rx
So I initially bound the receiver to my DX7, no problem. Then once I programed the model, I rebound the AR400, then did a quick test with all the components to make sure they all worked. Once I installed all the hardware and charged the battery, I plugged everything and turned it on. The LED on the receiver was blinking slowly, the ESC did its little beeping on energizing, then it started to beep like there was an issue. I checked the throttle stick position (it was down), and I tried the pitch/roll stick and nothing moved. When I unplugged the battery I looked up what the beeping from the ESC meant and it was "throttle signal abnormal". So I checked all the connections and did not see anything wrong. When I plugged in the battery again I noticed that the LED on the RX started bright then dimmed (not good, right). so I unplugged everything and tried the setup in a cheap old receiver that I had and everything works.
So does this mean I just smoked my new AR400?? How could I have done that? I checked the voltage out of the BEC and it was right at 5v so I am confused.
Thanks for the help
J
5x3 props
AR400 Spektrum Rx
Thanks for the help
J
