I've got two quads which in the past have flown without issue. I put them away for a few months and when I got home one wouldn't bind and the other was fine. I thought I'd try to swap out the Spektrum DSMX quad race receiver as I have the same on each quad. Also, I'm using a DX6e Tx.
I got the "bad" RX to power up and go into bind mode on the working quad, but it would not bind. I tried the working RX on the non-working drone and the RX would power up but not bind. So, then I put the working RX back on the working drone and... it would not bind. Made sure I was connected to the right port, getting 3.3v, proper transmitter settings... at one point I got it to bind and I flew for a day, and when I had some video issues I had to unplug the RX to get into the quad. Plugging the RX back in and I'm back to BIND FAILED world.
On the nonworking quad the RX will not light up and go into bind mode (the working RX would power up so I don't think getting 3.3v is the issue).
Recently I tried updating firmware, and I again checked all the ports and voltage. I also tried the command lines through Betaflight to put the RX into bind mode, I guess that kind of worked as I can get into bind mode easily enough... but I still cannot bind my TX. Yes, I stood various distances away and pointed my TX in everywhichway direction. Perhaps it's just time to give up on Spektrum? I've got some Crossfire gear sitting in a box... was thinking of trying of the FrSky X-Lite!?
Vortex 250 - IRCFUSIONF3 (*seems to only be the Spektrum RX causing issues)
FlexRC Owl (DIY) - SIRINFPV (*could be an issue with the board? I'm ready to gut this little quad and do a re-build.)
