Arcfyre
Hello folks-
Just wanted to share my latest project, a flite test simple storch built as a floatplane. I've always been interested in float planes and seaplanes, but they just aren't that compatible with foamboard. The moisture ruins the foam eventually and with it, your aircraft.
I decided to remedy that situation by building my FT Storch out of balsa wood. I used the side profile view from the plans, and then built up the fuselage based on that. There are a few advantages to this method, especially for a floatplane:
1. The firewall connection is rock solid and impervious to moisture. No more motors pulling themselves off the airframe!
2. The tail hinges are nylon reinforced with CA, making them waterproof and impossible to delaminate.
I was originally planning to scale up the FT simple floats to use with the Storch, but instead came across a local vendor who custom cuts them out of styrofoam. I chose 28" flat bottom floats for use with the Storch, and I'm happy with them so far. His website and information can be found at seaplanesupply.com
I'm working on getting some video taken, but for now all I have are the still shots. Enjoy, and happy flying
