Inspired by @buzzbomb and the folks building a profile 3D plane over in this thread (https://forum.flitetest.com/index.p...al-flying-with-a-two-dimensional-plane.60246/), I happened to come across the 4D Tensor on rcgroups which was a copy of an older horizon hobby plane.
Original plans can be found at:
http://www.rcplans.nl/catalog/product_info.php?cPath=31&products_id=43
I decided to shrink the plans so the entire wing could be cut out of a one sheet of DTFB. I ended up using ~28" wingspan which enabled the fuse to fit on one sheet as well. Adjusted the few slots for 3/16" DTFB and it was a very quick build. 1100kv motor with a 10x4.7 prop and 3 9g servos.
PDF plans attached below.
