Right... eventhough this is more a "preproject" rather than an actual project, I thought I might as well post it.
I've had my eye on a particular model for a while now, a small slope plank wing with a slight inverted sweep called the "Fiu". It's only 740mm in wingspan, but a fast little nervious thing on the slope.
This is actually the avatar of a guy on RCGroups who also made it. Hope he doesn't mind me using it, but it shows very nicely the end result.
Anyway... I wanted to make one with a couple of modifications, like clamshell speedbrakes on the tail and the wing in 2 halves, things like that. But due to the size, I found it rather difficult to imagine the exact placing of everything, like for example the extra servo and how to modify the wing. Seeing as I work better around a problem with something in my hands, I thought the best idea would be to make an original, with the only modifiction being the placement of the servos inside the wing. Now, due to limitations in aquirement of materials for this project, I am just making what I can for the moment out of material I already have, more a mental exercise at this moment. Anyway, I'm starting off with the fuselage, which I already have about half way!
I am making one small modification though, and that is a conduit for the antenna, as I still fly on 35mhz (our equivelent of your 72mhz over there). One thing I don't like about most planes is the way they were made or designed really nice, but no facilities added for the antenna, which has always ended up being "get it out however you can". This isn't a problem nowadays with 2.4ghz, but with the older equipment it was a bit of a problem than often became an eyesore. This plane is no exception, which if you look on the first photo, the antenna is just coming out throuth the wing joint with the fuselage. So what I did was make 3mm tail fin instead of 2mm, out of 2 pieces of 1.5mm, and scored a channel in the 2 halves, and stuck an interior transmision conduit inside which is 2mm in diameter. What it is is the white inner sleve that covers the transmision rods on the ready made systems. So I removed the metal core, leaving a 1mm hole down the middle... just enough to thread the antenna through, and stuck it inside the vertical fin with some epoxy. Then just glue the 2 halves togeather with some white wood glue and a bead of epoxy in the conduit groove, add a bottom fin out of some 1.5mm ply (rather than the 2mm balsa it says, as this will take the full force of the landings), and now I have a modified fin ready to add, with the conduit taking the antenna all the way up to the top tip internally from the front compartment
So that's it for the moment... one thing I am considering is on the final version giving it a 20% increase in size. This will put it into the 900mm category, and will give extra room inside for the modificactiobs, as well as justify a thicker fin for the clamshell brake, as well as an increased wing area for the extra weight, not to mention making a slightly more stable plane. And seeing as I want to make it with the wings in 2 halves, it will still be very transportable as no piece will be over half a meter long, ideal for sticking in a backpack and hiking a while, and if you find a nice slope along the way with a breeze, it all goes togeather in about 3 seconds, and on a 2S 700mAh LiFePO4 battery made out of two 14500 size elements (AA size), it will fly for hours with no need for the extra weight of a BEC or anything!
Anyway, I'm going back to bed to finish cooking this flu virus i'm currently incubating... the way I feel it might not be a bad idea to sacrifice a lamb and paint its blood on the front door!
