One of the Radiomaster R88 antenna missing
QuarkNova
I recently crashed my trainer model aircraft, and while assesing the damage, i found one of the antenna went missing.
What problems can this receiver cause with one antenna missing and is there any way to fix this?
I have attached an image of the same, please do have a look at it and lemme know.
AIRFORGE
Make It Fly!
You can get replacements.
Radiomaster Ants
Shurik-1960
Check the operation of the receiver with an assistant moving away at a distance of 300-400 m in line of sight in the field from the transmitter . If the torn antenna has not closed the input part and the receiver is working, fly and don't worry.
Crazed Scout Pilot
I have an extra radeo master 4 chanell receiver I can mail it to you if you would like. I will look at my r 88 but I believe that it is a solder on antenna. If you found the torn off antenna you can solder it back on.
You should be fine with just 1 antenna. The 2nd antenna is for redundancy, if something should block the 1st antenna. If it were mine, I would repair as soon as I could, but continue to fly it until I made the repair. I would range check it before I flew it. As it's always a good idea to do a range check after a crash.
Here is a video that explains how to solder the antenna back on
