SteveOBHave
Servo holes cut and hollowed out. I still haven't decided how I'm going to seat them, I'm thinking that a light ply insert or some sheet fiberglass might do the trick.
I've tunnelled out foam from the servo recesses and also through to the electronics bay. I've also made recesses for the servo connectors and the wires so that if I need to change them it's just a matter of lifting the elevons and swapping them out.
Both servos and control horns installed but not permanent yet. I will use a standard two part epoxy on the control horns but I need to be able to replace servos if they die.
Kahu will be pretty clean when she's all done and I'm still trying to decide if I want to put a duct forcing air both into the electronics bay and also to the motor of if I leave the motor in the wind. Again it's a case of making sure that I'm able to easily replace parts if they fail. I still need to figure out how to make the motor mount removable. The final thing that I will need to decide on is if the trailing edge in front of the prop needs to be streamlined - I'm guessing that if I want her quiet that a nice trailing edge will be needed.
This will be it till I can get back to the hangars because I need to clean up the elevon interfaces, probably with some micro, before I install the hinges and then it'll be test flight time!
