Progress Report: Hummingbird Plane V2
Hi Guys,
I got all the electronics mounted, wired and have it glued together. I must say, gluing the top and bottom sections in was no easy task. Getting the foam board to bend to all the curves of the head area was a challenge! I managed to figure out that peeling the paper off the inside surfaces, and then "rolling" the foam to help start it in the direction I wanted it to bend did the trick.
Applying glue, sliding the parts into place, and holding it where it would form to the curves as the glue cooled tested my resolve to no end! First, my glue gun appears to leave a lot to be desired as far as achieving delicate applications. Second, the tip opening is too large, and its difficult to get fine beads of glue. Lastly, even though its a dual temperature glue gun, the low temperature setting doesn't allow enough glue for longer glue runs, and it sets up way too quickly to try and slide pieces for proper alignment. I won't go into detail about how difficult the "trigger" is to pull and how that causes difficulty guiding the tip on the low temp setting.
The high temp setting seems to make the glue bubble/boil when applied, which causes the glue to squish out and requires a lot of scraping which causes a lot of glue "smears" in most of the joints.
In cases like this, I'm sure experience helps a lot in getting acceptable results, and that's something I've yet to gain.
I tried very hard to keep things lined up and square while gluing things together and I thought I did a fairly decent job, that is, until I decided to take some photos from various angles to share here. Upon viewing the photos I noticed that the tail seems to be a little off. The motor seems to be off center. The left and right body sections appear to be ever so slightly put of line.
Looking back on the mock up, the glide tests, and the adjustments I had to make, it would have very smart of me to put "reference marks" on all the "slots and "keys" to assure proper placement and alignment as I was gluing parts together. A very valuable lesson learned.
Overall, I'm pretty pleased with the results so far. Aside from the sloppy gluing and smear marks, I think the plane (I call it a plane) looks fairly decent.
It glides pretty well. The CoG is right about in line with the wing spar. The Hextronic 24 gram, 1700 kv motor seems to pull really well with 20 amp ESC, and a EP-7060 prop powered by a 800 mah 3 cell. When I say it seems to pull pretty well, I mean when I'm holding it. It feels like it wants to jump out of my hand at around 1/2 to 3/4 throttle. I can feel it wanting to nose up and nose down when I move the elevator, so I believe the prop wash is giving plenty of air flow over the elevator. (Is that an acceptable description?)
Now I'm torn between going ahead and adding some color and detail to make it look something like a hummingbird, or waiting until I can find an experienced pilot to try and maiden it for me first. I personally haven't flown since early spring and I have VERY limited time on my AXN flying with ailerons. I was just getting the hang of flying RET, and I know I wouldn't stand a chance of any success with this bird.
I know its just a concept and that it may never actually fly, but then again it may fly well enough to give promise to the concept. If it fails miserably as a flier I'll have a bunch of parts for simpler builds. If it flies with enough promise to inspire further development, then I will have learned a lot along the journey, and will have gained some valuable building/gluing experience.
I'm attaching some photos to share with those of you that have been following along, and as always, comments, suggestions, advice and bits of wisdom are always greatly appreciated!!!!
Thank You Kindly,
Randy
