The picture of the first tcopter I posted on the 2nd page has it's motors spaced at 17.5 inches.
I'm running hexTronik 24gram 1300kv Outrunners on it paired with Turnigy 12A plush ESCs w/ BLHeli firmware and 9x4.7 SF props. With a 3s 25c 2200mAh LiPo, AUW is around 550grams and I get about 12-14min flights.
A few moments ago, I maidened my new tri.
The motor spacing on it is 24inches, it's running DT-750s, F-30A ESCs w/SimonK, 11x4.7 SF props, and a 3s 30c 2450mAh LiPo. AUW 960grams. Since I have only 1 flight on it, and forgot to set my timer, I'm unsure of it's flight time. As a guess, I'd say it was around 10min. I'm still tweaking, and learning, the Megapirates firmware on the AIOP, so I flew it with an old KKboard (LOVE that old board, it's soo simple). It's by far the biggest multirotor I've flown, and it felt bigger in the air too, compared to my smaller tri which is a lot more nimble, but all-in-all, it flew really well. I think I'm going to like it.
Since you went with the 1000kv motors, depending on what props you use and your total flying weight, you'll be right on the edge with a 12-15a ESC, a 20A ESC would be ideal. That being said, if you keep your total weight down, run with a 9x4.7 or 9x5 prop on a 3s LiPo, you should be alright just so long as you don't fly it too hard. From reading the data other people have posted in the discussion thread, with a 9x4.7 prop, you can expect around 740grams of thrust at 11A. 740x3=2220 for a 2:1 thrust/weight ratio, your AUW should be around 1110 grams. Since you'll want to take it easy, as to not burn up your ESCs, keep your AUW around 900-950grams and you should be safe. However, if you were to use 20A ESCs, you'd have more wiggle room in the performance/payload dept.
