BlockerAviation
Pilot Blocker built from scratch a... I'm not sure what it is. We call it the Dragonfly.
Decked out with LEDs, an FPV camera, and all the ambition in Pilot Blocker's being. However, it took a few design tweaks over the months to get it just right. The maiden flight was earlier in the spring, and ended abruptly after going head on with a fence (we flew in a nearby baseball park). The camera on the bottom rotated, and was the beginning inspiration for the build. However it was never used during flight.
Some time later, fitted with a new wing for stabilization, and a redone tail, it flew rather well. However there was the issue of power from the motor--or lack of it. At full throttle, it needed a perfect drop in the ground to get the air under the wings as it needed to get in the air. Subsequently, it hardly had the power to remain in the air.
But after the final tweak to the angle of the motor, everything was in place--except getting off the ground. But we had an idea for that...
I apologize for the shaky camera, we have no better equipment. Just don't watch in VR and you should be fine.
We used a long piece of kite string that was tied to a key ring on each end. One key ring attached to the car, and the other end hooked onto a hook on the belly of the plane. When the car slows down enough, the momentum of the plane continues, and the key ring on it slides off because there is no lock. This is when the pilot takes control of the plane and flies it under its own power.
We have future plans to build a much larger variant, allowing for more of our bad ideas. Let us know what you think!
