As I suspected, very old firmware with the current configurator. 2 options, either get an older version of the configurator, or flash a newer firmware. Personally, I'd upgrade the firmware to 3.5.7 There are many videos on youtube to walk you through the process. First step is to back up your current settings. In the CLI tab enter the diff command, then click the save to file button on the bottom right of the window. This will give you info you might need to setup the new version.
