Is it possible to build a tricopter and use only one 40 amp esc? Thank you!
agupt108 Member Feb 22, 2023 #1 Is it possible to build a tricopter and use only one 40 amp esc? Thank you!
LitterBug Techno Nut Moderator Feb 22, 2023 #2 agupt108 said: Is it possible to build a tricopter and use only one 40 amp esc? Thank you! Click to expand... Nope. You need three ESCs. One for each motor. You can not drive more than one motor with an ESC. They read the flyback pulses from the magnets. That said, if you use one motor to drive three variable pitch props, it could be done.
agupt108 Member Feb 22, 2023 #3 Thank you! Any other ideas as to what I can do other than RC planes with all the parts of an rc plane...interested in trying out something else.
Liam B Well-known member Feb 22, 2023 #4 agupt108 said: Thank you! Any other ideas as to what I can do other than RC planes with all the parts of an rc plane...interested in trying out something else. Click to expand... Build a propeller powered car.
luvmy40 Elite member Feb 22, 2023 #5 Hover Craft Everglades fan boat I'm sure I can come up with something else given enough time and lack of sleep
LitterBug Techno Nut Moderator Feb 22, 2023 #6 Air boat. I've built one from a servo, motor, and one ESC. Works on both Water and snow.
