FlyWithMoh
Just Starting Out...
I am just starting out and I'm trying to verify that if I pop a 3 cell battery into the "power pack a" that the ESC is not going to burn when I do WOT (wide open throttle).
From what I can tell the motor, and the ESC will support the 3 cell. My concern is that I believe that since I am going to be using a 6030 prop that comes with the power pack, will it make the motor pull more than the ESC can safely support? I am thinking that I should drop in a 5030 prop to be safe.
does anybody have a online calculator or tool that will help you determine the proper power pod setup? I know the FT Guys have touched on this but I just wanted to double check my setup before I fly.
Here are the spec I am looking at that say the engine will pull 11.3a with a 6" prop: http://www.emaxmodel.com/emax-multicopter-motor-mt1806.html
