Twinstar II Brushless Setup?
metteigel
Good Day People!
I'am searching for a (Hobbyking only!) Brushless Setup for my FPV Twinstar 2. My Budget is baout 100$. Do you have some Links for me ? ;-)
Greetings from Germany!
colorex
Rotor Riot!
You could also try these motors:
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=19035&aff=524347
with these props:
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=7944&aff=524347
and the ESC's you prefer:
30 Amp: http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=18004&aff=524347
25 Amp: http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=18003&aff=524347
The Turnigy Plush ESC's are usually better, but they are rarely in stock. I run this setup on a 25 Amp Red Brick ESC, and it gets barely warm. Running two of them on the same plane could probably run cooler.
Remember that you need two motors, and 2 ESC's as well.
You could get more power using these props, but they might be too much for the motor. Don't trust me on this.
8x5E http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=7945&aff=524347
8x6E http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=7946&aff=524347
9x6E http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=7951&aff=524347
Mind you, both props are on backorder.
