I would possibly be interested in a group buy if more were interested.
Messed around with the PDB for the quad today based on Jhitesmas recommendation (cheaper to order test boards for the quad vs hex
) The Pololu voltage regulator has one terminal that's labeled SHDN which I'm not sure what it does. Right now I have 4 solder points for the voltage regulator with the upper most one (SHDN) going nowhere. I'm hoping someone with experience with this regulator will be able to tell me if it's needed or not. Otherwise I have the positive and ground connections right next to the regulator, and a 1mm wide trace going from the VOUT to a spot on the PDB next to a ground to power the FC.
Outside of that, top plate serves as the ground connections, bottom is positive with through points for each positive pad. I really hope jhitesma and Thurmond will see this and be able to provide feedback.
Jhitesma, this is wired up the same way as the hex board I sent you with the same type of errors. If you'd like, I can email this file to you as well.
Thurmond, I can also email you this file if you'd like to take a look at it. PM your email and I can send it your way.
Top: The big rectangle at the top of the board is the
Pololu voltage regulator.
Bottom
