I have 3 20a BS ESC's I could experiment with. Think I may just order a set of the bs12 clones from RTFQ and give them a go though. Would rather have it in the air than trying to determine on the bench if the motor sounds any better. I see the bs12 clones from RTFQ actually have programming pads so they're a step up from the real deal and will be easier to reflash with blheli if I go that route. But first...
If you could check your PID's and let me know that would be great...I'm running closer to 2-3 so maybe these just really want considerably lower PID's than I expected. I've dropped down to 1.7 but was hesitant to go any lower ( I run around 7 on my knuckle with 2212 Angels and 8" props - it used to run around 2 when I used the original WII gyro and stock ESC's but once I upgraded to the MPU-6050 I was able to push them up to around 4-5 and once I flashed to simonk I was able to keep pushing them and get tighter response.) Maybe I just need to really drop my PID's lower than I expected on this setup. I may give that a quick try over lunch. I started around 2 and it was ok, but when I bumped it up to 3 it really felt great - but shortly after was when all my problems began and I haven't gone lower than 1.7 since...maybe my tune is my issue. Just so many variables to test...and I admit with the lack of built in USB I'm really lazy about changing parameters on the afromini since hooking up the FTDI is even more of a pain now that I have the top cage installed.
Horizon really does make flips easy, but it starts feeling so limiting after trying acro I still like horizon for showing off in tight places, but when I have more recovery room acro is just so much more liberating to fly now. I'm dying to see what you can do if you get out to a bigger field!
