Raptortech
Foam Addict
I'm in a robotics class, and my team has a $1000 budget to build something awesome. Half of us want an ROV (submarine) and half of us want something that flies. The obvious compromise is a machine that can do both.
After some discussion and research, it appears that the best way to go about this would be a multirotor. This because it is already heavier than water, and has all the mechanics it would need to maneuver both underwater and in the air.
The basic idea for this multirotor (probably a quadcopter) is that it would land gently on the water and sink below the surface. Once submerged, the pilot can turn on the rotors again (at a significantly reduced power), and control the craft. To takeoff, its as simple as ascending to the surface, and once all the rotors are clear of the water, powering up and lifting off.
We found a video of a guy doing just this in his sink with a waterproofed toy quadcopter:
Fortunately, brushless motors are waterproof (to an extent), and FT just released a video on waterproofing electronics! This craft is designed to remain underwater for more than just a moment, so we would likely make a water proof container for the flight controller and receiver. This will also help with buoyancy.
The main challenges for our group:
--Ordering parts because the school has specific websites that are available to order from due to some funding policies. We are working on getting dx.com approved.
--Waterproofing. It's never perfect.
--Radio range underwater is significantly reduced, so we may need a more powerful transmitter and improved antennas over stock 2.4GHz radios.
--We do not know how a quadcopter will handle underwater. It may be the case that the motors simply stall. This could require modification of the flight controller firmware to optimize handling, as well as special ESCs or under-propping the motors.
The reason I am posting this is because I would love to know if anyone has an ideas about how we should approach this project, or any experience with underwater RC. It's also kinda cool, so I thought you might be interested
