I made up a 4x cell nihm pack from 4200mah 1.2v turnigy cells. Came in at 273g. I put this in the power pod right up against the firewall. Still had to slide the power pod forward so the firewall was even with the front of the plane, but it got cg without having to add any dead weight. Should power the 4 servos for like a week lol. No really.
For charging the battery i added a pretty common part used in slope planes. Its a switch charge jack. When the pigtail is plugged in, it disconnects the receiver and allows you to charge the battery. So to turn the plane "off" you plug it in. As soon as you unplug it the reciever gets power.
I had some old nose cone laying around that looked like it would fit and sanded it up and painted black. Couple big globs of hot glue on the four corners of the firewall and its on pretty good.
And than the decals from callie graphics. Had a few spots where i must not have sanded it well enough and the transfer tape pulled paint up. Once i realized this i would put the decals down, heat it up with an air gun, than slowly pull the transfer tape off. This made a big difference and i had a lot less paint damage. I will have to spray some paint into a cup and paint brush the spots i messed up. At this stage, in the pic below, i have about half the decals on. As i suspected from
@Mid7night comments, the 1/10 size decals are a little big for this plane. Some go on just fine but others will not fit at all. Thats ok, ill just put them on the bottom side of the wing and cut the excess off.
After all the decals are on i will do a protective coat of some type to give the decals some sun protection and belly landing protection.
