Nardoticus
For those of you who are too impatient to order a motor mount for the pusher, here is a suggestion.
You can make a pusher motor mount from the foam board.
1) Cut out foam board equivalents from the plans. You need not cut out the firewall, you should use plywood for this.
On 6 of the triangles cut off the bottom tab.
2) Assemble(hot glue) the tabbed triangles with the bottom plate. Insert and hotglue the untabbed triangles in between.
3) Glue Firewall to assembly. Then attach the motor.
