Vortex 150 Arming Switch
Vman
Just got the vortex 150 and maddened it tonight. With the 4 cell it was too much for me in a gym. My other quads I arm with a switch on the transmitter and I prefer that to move the throttle to bottom left or bottom right for arming or disarming. How do I change this? If i have to do this via computer and Vortex Companion app why do I have problems trying to open a serial port?
Vman
Solved the problem with the serial port connection. I tried a third US B cable one that is made of heavier gage cable. This one worked fine no problem. So if you are trying to program a quad with Betaflight or Cleanflight or Vortwx Companion and get cannot open serial port error message all the time and you have tried everything else then try another usb cable.
#7
vortex 150
i have the same problem... i can't connect my vortex 150 into my computer... always failed serial port... and the immersionrc USB to UART driver can't install... i am using FRsky w/ x4r receiver... anyone knows how to fix this?
Vman
Seriously try a new USB cable. I even went and bought a cheap chrome book to eliminate if it was Dell or Windows problem. That didn't help either until I tried a new cable. It worked on the Chromebook so I tried it on my Windows desktop and it worked there too. In windows go to the device manager to make sure you are opening a com port, this com port is the one you select in betaflight or whatever program you are using.
#9
vortex 150
i tried different usbs but still nothing... so i plug in another computer and it works... maybe just my computer and needs to be replaced... all good now...:)
#10
sometime even a different USB port on same computer will make a difference. Is it USB 2.0 or 3.0, mine won't work with the ports on top or in back only the front ports.
