Waiting for delivery!
CarolineTyler
Frame: HSKRC TWE210 (The frame UAV Futures feature in their $99 build)
https://www.banggood.com/HSKRC-TWE210-210mm-Wheelbase-4mm-Arm-3K-Carbon-Fiber-X-Type-FPV-Racing-Frame-Kit-for-RC-Drone-p-1283150.html
Motors: 2x Turnigy D2205-2600KV
https://hobbyking.com/en_us/brushless-motor-d2205-2600kv-ccw.html
https://hobbyking.com/en_us/brushless-motor-d2205-2600kv-cw.html
PROPS: Dal Cyclone T5040C Triblade
kingquad.shop
ESCS: 4x Racerstar RS30A Lite 30A Blheli_S BB1 2-4S
https://www.banggood.com/Racerstar-RS30A-Lite-30A-Blheli_S-BB1-2-4S-Brushless-ESC-Support-Oneshot42-p-1100236.html
Power Distribution: PDB-XPW PDB W/ Current Sensor 140A Dual BEC
https://www.ebay.co.uk/itm/PDB-XPW-PDB-W-Current-Sensor-140A-Dual-BEC-for-FPV-Racing-Quad-QAV250-RC541/153187140880
CPU: Matek F405-STD Betaflight Flight Controller
https://www.unmannedtechshop.co.uk/matek-f405-std-betaflight-flight-controller/
Camera: Caddx Turbo Micro F2 FPV Camera
https://www.unmannedtechshop.co.uk/caddx-turbo-micro-f2-fpv-camera/
VTX: Eachine TX801 5.8G 72CH
https://www.banggood.com/Eachine-TX801-5_8G-72CH-0_01MW5MW25MW50MW100MW200MW400MW600MW-Switched-AV-VTX-FPV-Transmitter-p-1147691.html
Arial: Pagoda LHCP/RHCP 60mm 5.8G 2dBi FPV Antenna
https://www.banggood.com/Pagoda-LHCPRHCP-60mm-5_8G-2dBi-FPV-Antenna-SMARP-SMA-With-Case-RedPurple-p-1224234.html
Receiver: Frsky XM+ Micro D16 SBUS Full Range Mini Receiver
https://www.banggood.com/Frsky-XM-Micro-D16-SBUS-Full-Range-Receiver-Up-to-16CH-p-1110020.html
VTX to be replaced by Eachine TX805 5.8G 40CH
https://www.banggood.com/Eachine-TX805-40CH-25-200-600-800mW-FPV-Transmitter-TX-LED-Display-Support-OSD-Pitmode-Smartaudio-p-1333984.html
CarolineTyler
Going to try this cute transmitter Arial, it looks so good. Bit worried that mounting it in this way may cause poor signal when the quadcopter is facing me, the carbon frame and top mounted battery will be causing some signal blocking.
