WE WANT A SR-71!
You might reach out to @Inq, if I recall, he had an interest in the SR-71.
Be patient, he has not been around for a while.
short_nathan
Hey, you should put an article called "We want an FT SR-71!!!" in the FT website (because there are like 3 articles per year nowadays)
Tench745
I don't think using the articles section to beg for a new plan is going to be particularly effective. I'm not certain, but I believe the moderator for the articles is a volunteer, and not part of the usual FT crew.
short_nathan
There are no new *fun* articles, so it would be fun to add something, and it would be more convincing if someone posted a (very) good design of an SR-71.
Tench745
Have you seen the SR 71 a guy on the Facebook page has been working on?
Burnhard
To be fair, while the original thing is a technical marvel, I don’t believe a foam model will be much fun.
The original was designed to cruise at high speed for long periods of time, that’s something that cannot be easily replicated for a model.
More serious, with that design, maneuverability will probably be an issue. And even if it flies, it will not have much presence in the air.
quorneng
You could say the same for any RC model of a supersonic jet. None really fly like the full size yet they are still very popular builds.
It depends on the definition of "fun". Getting a model of an exotic design plane to fly controllably may be all the fun required!
I agree with @quorneng: if it flew realistically, you would need a city sized place to fly it because standard rate turns would be about a mile in diameter at about 150 mph. A standard rate turn in a real one around a VOR is about 200 miles or just about the maximum distance you can you could get the VOR signal from 80,000 msl. And that's just a two minute turn. Lose attention for a second and you have lost the plane. Friends said "You havent been lost until you get lost at mach 4"
L Edge
It is great fun in getting a exotic design to fly from launch to land and by the way, the pilot needs to massage the throttle, control the nose and rudder and really feel the plane to keep it in the air and land successfully.
This is initial flight inside a 400 ft square area(houses behind trees, can't crash or retrieve) and not trimmed.
When a designer moves from prop to EDF's, it takes an additional set of new rules to get it to design, build and fly. Applied that to the Warthog A-10, and I can very comfortable attack at 6 feet and turn and burn if I want.
Got my Dark Star going the same way even made out of Adams foam.
Learn even more as exploring EDF's. Any exhaust nozzle that is not exiting parallel to flight, will cause a pitch up to your plane, especially the rudderless type.
Go to my youtube site to see other EDF planes flying.
