Matthewdupreez
if my cord is about 25 to 20 cm...
what angle of attack should i use?
and what thickness should i use
i will measure my foam block so i know what the chord will/can beif my cord is about 25 to 20 cm...
If you just want to have a decent fun flyer. The standard Clark Y is a good choice. Make a thinner one, maybe 9-10% of the cord in thickness.
I’m not going to be of any help if you are wanting to make a competitive flyer.
will post pics tomorrow80% of wing completed
For a rectangular wing, The CG shoud be at 25% of the cord. Example: If the cord is 10 inches the CG should be 2.5 inches from the leading edge.can anyone tell me where the cg should be on this wing...
it is not a swept wing. it is a straight wing...If you are planning a swept wing, you need to find the MAC, mean average cord. The CG should be at 25% of the MAC
I set the CG at 25% for the maiden flight, for improved stability. When the plane is trimmed out, I will start moving the CG aft until I get the amount of instability I prefer. The CG usually ends up being 27-30% of the cord.so i will go for about 30% of cord... for the cg...
25% it isI set the CG at 25% for the maiden flight, for improved stability. When the plane is trimmed out, I will start moving the CG aft until I get the amount of instability I prefer. The CG usually ends up being 27-30% of the cord.
oops please excuse the masking tape on the one wing... it was to prevent the wing sticking to the table
