I just got done scratch building a modified 70% scale ft-22. I have a suppo 1806 2660kv motor with a 10amp suppo ESC that has a 1amp linear BEC and I am powering it with a 2s 500mah lipo.
I calibrated the ESC for mode 1 which is for a LiPo setup. The problem I am running into is when I try to use the control surfaces the motor dies and goes back into programming mode. I don't know if the ESC is bad or if this is a brown out. The BEC only has to push two 6gram servos.
Here are some pics of my build.
