would it work....
f-35lover
Hi, after well "flying" i desided to make a edf plane, the plane sugestes a 2840-KV3150, motor a 4 Cell 14.8V 2000 – 2600 mAh Lipo and a 40a esc. but i want to know if it is possible to use a 2822 3500KV instead. will it work or will it burn out?
It would probably be massively underpowered. Going from a 2840 to a 2822, you will be cutting the height of the motor almost in half. For a 2822, 28 is the diameter, 22 is the height.
