leaded50
Make it in the size you want, here plan are for a 600mm wingspan. A 2205 motor will fit fine. 4X 5g or 9g servos, no problem. Its a plane that can glide nicely.. or do acrobatic, your choice. easy build! small battery, big 2200 mAh battery? you to choose.
Doesn't self-correct to level like a beginner plane would. If you bank the wing, it "stays there" until you tell it to do something else. It feels similar to a 3D pattern plane. The X shape fuselage and V-tail design allow the plane to track straight and turns can be made with ailerons bank and yank style, rudder only, or a combo of both. It can be very precise if you want.
Slows down to a crawl and stays under control.Inside or outside use, even if its light, so careful in windy conditions
