Y6AP, Hexacopter
w4mps@nc.rr.com
I'm building the Y6 Hexcacopter (Eric Monroe) https://youtu.be/Z9NJQJv6lw4
I've just finished soldering the ESC and battery cable power connections to the electroplate board. All solder connections look good and I don't see any evidence of solder bridges between + and - . With the ESC's and motors connected I'm getting a low resistance reading when checking for continuity (+ to -). I don't believe there are any shorts. Can anyone advise what I should be seeing when checking with my ohmmeter. I'm sure there is capacitance with the motors and ESCs connected but not sure if there is another problem I should be checking for. Many thanks.
Marc (W4MPS)
FPVology
You can always plug in using one of those light bulb thingies. the bulb will blow before anything on the copter gets fried.
Check it out HERE.
