Jameshavoic84
Hello
I'm building my first quad (Mr Steele config) ImmersionRC Alien 5" etc.
My Alien PDB has not got any continuity issues. The - to - terminals is a closed circuit and so is all the + to + terminals. The PDB - and + is open and not connected when testing continuity. All good there.
The Kiss ESC is another story
. I've soldered clearly making sure no solder is connecting or bridging across anything, however i'm getting 70% resistance connection when checking - and + Kiss ESC terminals with a constant continuity beep that never disappears.
I understand a short beep could occur due to capacitors charging but I don't think this should cause a constant continuity beep.
Has anyone else soldered and used Kiss 24A Race Editions ESCs and got a closed circuit when testing - and + terminals?
Have I introduced too much temp into the ESC and nuked a chip causing a short?
Everything I've read and watched tells me there shouldn't be any continuity between + and - terminals anywhere on the quad. On the Kiss ESC, I should be expecting infinite resistance (open circuit) on the + and - terminals, yes?
https://youtu.be/_p1DyLZcabE?t=3m clearly has no connection (beep) on Kiss ESC - and +.
