BI-PLANE WING ALIGNMENT
Since I had the model "in the bones" it would be a good idea to align the wings, check the incidence, decalage and drill the interplane struts. For some reason Sig has you do these steps after covering the model towards the end of the build. In my opinion, this should be done way before you cover or finish the model so you have a chance to correct any problems early on.
The incidence for this model is 0 deg for all wings and horizontal stabilizer. Using the Robart incidence meter everything was checked and came out perfectly, so I drilled and bolted the interplane struts, making sure there is a small gap between the wings and interplane struts to account for covering and to resist binding (per the plans). I also measured and set the top wing to match the bottom between the wings and to the tail, also checking visually the leading edges to make sure they matched.
I also drilled out some 4-40 blind nuts and will install them in the interplane struts so there will be some built in washers and protection from wear to the light ply that the interplane struts are made from.
Meanwhile, work continues on the horizontal stabilizer. There was a lot of Titebond II applied to the frame when gluing on the sheeting, so I am letting it sit under some magazines on my flat building board for a few days, while I do other work, to resist warping while the moisture dries out of the glue.
