MODS: Bigger motor, semi symmetrical wing (I accidently built the wing this way, see picture below), taped wing leading edges with heavy duty 3" packing tape, taped hinges with 2" packing tape, ironed all wing edges for better aerodynamics and looks, reinforced landing gear mounting areas with extreme packing tape on bottom and top of fuselage, reinforced wing dowl rubber band mounting areas with paint sticks inside fuse, installed a tail wheel that casters (not steerable for now), and Minwaxed entire model then used Cricut decal material.
To explane the accidental wing design: I taped the leading edge of wing with heavy duty 3" packing tape to protect it from impacts (I found this worked on the last Storch amazingly well). I taped the wing before I built it when it was flat board so it was easier to tape and looked better. The problem I had when I went to fold the wing over is that the tape caused the bottom of the wing to angle up a bit exactly like the wing in the middle of the picture. The tape caused the wing to be too stiff in this area, but it was perfect all the way accross, so it came out great (happy accident). I have yet to see how it will fly, but all my research shows that it should be more areobatic! Also, when I mounted my larger motor, I had to lower the motor a few mm to get it to fit correctly. That changed the thrust line alignment slightly which should compensate for the reduced lift of the wing (another happy accident).
I wont know until I get her in the air, but I have a feeling that it should fly very nicely.
I am also using a Turnigy 3s, 2200, 40c battery that balances the model perfectly. I havent weight her for a final weight yet, but last time I weighed her she was around 1,000 grams.
