WING REINFORCEMENT FIX FOR TRAILING EDGE BUCKLING
Here is my fix for the rear of wing buckling. I used carbon fiber as the bbq skewers flexed to much.
BEFORE
AFTER
Start by flexing the bent part straight and actually flex it past straight a small amount, then poke small bbq skewers through the back of wing all the way into the wing spar touching the wood in spar.
Then poke the carbon rod into the same hole all the way to the spar and mark it to cut to size.
Now, with the carbon rods cut, inject a healthy amount of hot glue into the holes and install the rods as straight as possible into the holes making sure their flush to the wing edge and touching the spar. Do one at a time.
Now finish up with a little hot glue in the spar area where the rods barely poke through touching the wood, you have to drip it in as its hard to access.
Finally have a piece of foam board cut to size, mark where the carbon rods are going to seat on it, make shallow cuts on those lines, take a bbq skewer and go over the cuts so the rods will sit in the fb tightly and apply hot glue to the piece and install. I pre-bent the piece also so it sits better on wing.
There ya go, it seems to be super strong now! I will report back later with how it holds up over time.
