MC Mini Sport 30"
Plane MC Mini Sport 30" v1.0
Please log in to download
Type
Build Plan (PDF, AI, etc.)
Simple build, great sport flier, great for a trainer.
30" wingspan
1806-2280 motor
850 3S
4 channel
thrust angle 2-3 degrees right, 5-6 degrees down
AUW 280g
Please note this is not a speedbuild kit to cut-glue-fly. You'll want to make a couple decisions during the build process, and some prior build experience is assumed. I've built a fun plane and you can download and use the plans I made for my build. Use it as a template, a pattern or a suggestion to create your own awesome plane!
Build thread/discussion/videos HERE
NOTE: In trying to make this nice & easy, the downloadable pdf is formatted to 10 sheets of 8-1/2x11". Make sure you're set to "no scaling" or "scale to 100%" and also "center the plot". Try only one of the sheets to start.
If there are issues and you can't print it right, let me know and I might need to set this up in large sheets to be tiled by your idiot printer.
;):p
318328_044d02468c960e63c96085f339082d93.jpg 318329_62e99f4da30ad66c38c703733d8d5f6a.jpg 315991_d643a031722e0a8d47d80c8594b020fe.jpg 315992_35a8384037ac890fdf19634242347fa6.jpg
This is just a preview of the work before I created the downloadable pdf:
Author
Monte.C
Downloads
53
Views
283
First release
Last update
Rating
4.00 star(s) 1 ratings
Latest reviews
It was definitely a more advanced build and the plans don't guide you through the process, but there is a lot of room to make this plane your own, modifying as you build.
It seems to fly reasonably stable even without rudder. The only thing I can recommend is a stronger power pod and doublers in the nose and some reinforcement where the wings mount. Something I also noticed is that there is a lot of room inside the fuselage which you might need for wiring or sensors.
Monte.C
Monte.C
My friend I'm so glad you've built & flown the plane. You bet, it might be good to make the fuse 1 foamboard layer wider on each side to make room for doublers in the nose and under the wing. I haven't tried it with more power - honestly I'm new, this is the first plane I ever flew and under those conditions it had way more power than I needed! Thanks and I'm glad you like it.
