Universal RX and VTX Cradle Cap
Part Universal RX and VTX Cradle Cap 2019-03-02
Please log in to download
Type
FPV Quad Drones in mind mounting electronics had been make it up as you go.
So I designed bracket to site above the Flight Controller board, one for the 20 x 20mm mounting and for the 30.5 x 30.5mm mounting FC.
3D Printed using PLA the weight is under 1g, trying to fit a wide rang of video transmitters as well as remote receivers.
Dimensions.
20 x 20mm Mounting
RX: 25 x 13mm
VTX: 19mm Wide 21mm Length
30.5 x 30.5mm Mounting
RX: 38 x 13mm
VTX: 31mm Wide 33mm Length
As most video transmitters and remote receivers don’t have mounting holes, either use double sides tale or small drop of hot-glue in the corners.
