That's some weird looking doculam you got there
You noticed?
When I restored the "One Nite" I covered it with tissue; first tissue job in 45 years. I really enjoyed the task though I had to strip and re-cover the wing and tail feathers a number of times until I got the hang of it. I enjoy working with tissue a lot more than iron-on film.
Top side of the wing. I knew I couldn't cover the wing tip with a single piece of dry tissue without getting crows feet wrinkles around the edges. So I wanted to see how much this tissue stretches when damp. I applied the glue stick around the outside. Then I misted the paper very lightly with water, just enough to make it sag. It worked! I very gently pulled the tissue taut over the outer rib. When the tissue started to shrink before I had it perfectly smooth I lightly sprayed it again. Working slowly and very carefully the tissue wrapped around the wingtip without any wrinkles.
Top of the main section of the wing, covered and prior to wetting and shrinking.
Completed wing. No wrinkles.
I am very worried I will accidentally puncture this before the first flight.
Jon
