Ryan O.
Out of Foam Board!
The motor box and shelves are installed. For the shelves I sandwiched one piece of elmer’s foam between two pieces of ft foam, with the grains at 90 degrees to each other for maximum strength. I then glued in the top one. Before I glued in the bottom shelf, I made my motor box. I took the spare firewall out of the shinden and glued it to a 13.4x13.4 cm foam board box. I then used a lot of extreme packing tape along the sides only to reinforce the joint between the firewall and the box. I didn’t tape over the top and bottom because that’s where I’d be gluing them to the shelves. I then glued the motor box to the shelf and followed it up with some more extreme packing tape, just to be safe.
I’ve decided to make the batteries load in from the top where they will sit as far forward as possible.
After I finalize all the reinforcements and access holes, I’ll update the plans.
It turns out I’ve been pronouncing Flivver wrong this whole time.
