3 Leaf TX and 4 Leaf RX Antennas - Why?
kah00na
Is there a simple explanation of why there should be 3 leaves on a TX and 4 leaves on a RX antenna? I'm referring to 5.8/1.2 FPV antennas. What happens if you run 4 leaves on a TX or 3 leaves on a RX? I'd guess some range reduction but I'm not sure why.
jhitesma
Some guy in the desert
It will work either way. Just the radiation pattern on the antennas give a slight advantage with the 3 lobe on TX and 4 on RX. You could also run 3 lobe on both ends or 4 lobe on both ends.
