telnar1236
Over the past few months, I have taken a design for a large firefighting/cargo aircraft created by myself and a few others and turned it into a large 3D printed RC model. When I was looking into sizing the airplane to reduce cost as much as possible, I was very surprised to find that with a few components I already had, a 1/20 scale model with an 8 ft. wingspan and a takeoff weight of 4.5 kg with no additional payload would be the cheapest option at only $164 in materials and electronics, so I went ahead and designed one of the largest 3D printed models I am aware of. It flies on two 5000 mAh 4s battery packs (one per wing) and is the largest airplane I own by a noticeable margin (this is a challenge since it barely fits in my car even without the wings). It flies very well and is exceptionally stable but is also quite heavy and turns very slowly. The STL files for this airplane are not in a usable form so I will not be posting them, but I thought that this was a good example of what is becoming possible with 3D printers and cheap electronics and that I would post it here. The structure is fully 3D printed with the exception of three 10mm carbon fiber spars in the wings, four 3mm carbon fiber spars in the tail, and steel mounting pins and axles in the landing gear. The wings screw on and are removable to make transport possible.
Here are two photos of the plane on the runway and in the air:
And here are several photos from during construction including one showing the internal structure of the fuselage:
