It's not a 3d lab prints...but....
Looks pretty darn perfect to me Jason. I saw that plane on thingiverse and a few video's the guy made on youtube, he is one smart kid!
I've been having more luck too. Couple of changes made a huge difference.
1st is the spool holder, I quickly knocked up this, the spool now rotates on two bearings, the oiler also helps keep tension and stops the spool uncoiling. Must replace the wood with a 3d printed version soon.
Couple of settings made a huge difference.
Turns out I was under retracting. The 3dlabprint settings file had a setting of 0.3mm. I found what was happening was the under retraction was leading to little nodules at the end of sharp points and corners which could in turn catch and interrupt the flow while printing the thin wall. I experimented and found a setting of 3.0mm worked much better.
The other change I made was to the acceleration parameters. They were set too high by default and caused a shake when changing direction suddenly. I knocked 20% off the accelleration and the difference is very apparent. Even the noise of the process sounds better.
The problem is now I'd love a second printer to speed up the process. However if my wife ever even reads this post, I'm soo dead!
