That is the recommended prop for Power Pack C, but the pictures show smaller 3 blade props. I think you're supposed to go down in size a bit when you add a blade. A few props of some kind should come in the kit though.
The 60” C-47 came with 8” 3 blade props in the speed built kit. I assume the 72” does as well. The C-47/DC-3 has engines mounted very close to the fuselage, so the scale model does it the same. The 60” has no room for anything bigger than 8” props.
