FinalGlideAus
terrorizing squirrels
You can thank Balu for this thread. He put in a great amount of work to write this up. Balu and I are just glad people are getting something out of it. Makes the work worthwhile
Hydecyde, I think your 45A ESCs are overkill but I think the hardware can fly on a 3S battery (you didnt mention battery and that is key here too).
The 750s are commonly used but are a large motor for this frame and will present more of a challenge to build. Smaller motors (lequipment 0kv Suppos from AH) run shorter rotors, don't lift as much but are quicker to respond and tend to produce less vibration and require less balancing and tuning to get to fly well.
I would recommend you start a thread for your build so we can give you more personal attention. Be sure to post pics and video (we like pics and video here).
Welcome to FliteTest Hydecyde. I am looking forward to seeing your builds.
One last question guys..regarding the props do they all have to go the same way? As in all ccw or all cw? Since the yaw is controlled via the aft servo pitching the prop?
Thanks in advance.
I would like to add two thoughts.
1. The more your copter weighs and the higher you fly, the more you risk your insurance.
2. The more ridgid your rotors, the more risk you have to your fingers. Nylon rotors hurt and may cause you to run for a bandaid. CF rotors may cause you to have to run to the hospital. Nylon rotors can remove fingers but just are not as likely to. Ridgid rotors tend to balance better and be better for video but when learning how to fly, stick with nylon and graduate to CF or glass reinforced. They are cheaper and less likely to send you to the hospital with your finger in a plastic bag on ice.
I think that's a good idea.What do you think, should I move this into the newbie section?
