BATTLEAXE
And here is how that turned out:
You can see the skewer spar in the center of the 2 halves...
With the top layer of the KFm wing in place, covers up the spar and strengthens the wing. I am trying out the Gorilla spray adhesive this time. I found when I sprayed directly to the FB it wetted the paper enough to bubble it up some, once glued on it wasn't an issue, thinking of it now though next time I will be removing the paper from the contact areas to see if there is a better bond.
