Got the canopy/battery hatch figured out, it's amazing what kind of ideas you come up with mid build sometimes, unless this is just a happy accident of sorts. Check it out:
Looks pretty stock right. I was thinking of making this all one piece just like the plans called for and Bix did in the build vid. But when I glued the front canopy together I made it a little narrow to fit properly on the nose, so it really squeezed onto the upper nose plate and would be hard to keep down in flight, took a bit of pressure to hold it by hand. So I glued it to the fuse...
Then I cut the back part off to make the hatch. I did want to hinge it up from the canopy but this added some pressure on the top of the wing to the hatch and made things a little awkward, that idea was out. This is the cool part, literally...
These little vents on each side direct air straight over the battery, ESC, and motor which is exhaust center out the back. Fricken brilliant if you ask me!
I will index the front of the battery hatch with pop sticks or skewers, and the back of it will be most likely Velcro.
I still have formulate a plan for the motor pod... to be continued
