A few weeks ago, I decided to build an acrobatic quad.
Helped by the wisdom and guidance of both Cyberdactyl and FGA, I settled on a design largely inspired by Warthox's Mini CP.
As it is my first scratch build, I feel like keeping a log along the way
The specs will be as follow :
- Carbon fiber center plates with carbon hybrid arms (around 300mm motor to motor)
- Sunnysky X2208 1500kv outrunners
- HQ 8x5 CF-reinforced props
- KISS 18A ESCs
- Naze32 Acro
Here's a preview of the design, made with FreeCAD :
Part I - Cutting the center plates
The first thing I did was cutting the center plates, from a 2mm thick carbon fiber sheet.
I printed a few 1:1 patterns, cut them out with a hobby knife, and taped them onto the CF sheet.
Using a dremel tool on a vertical stand, I first tried some #113 bits. They're cheap, and said to be able to cut through light metal.
Unfortunately, the first one I tried became dull after just a few centimeters.
So, I switched to the much more expensive #569 grouting bit... which cut through CF like a hot knife through butter.
In fact, it cuts so well that during my first attempt, I let the plate slip and it made a deep dent :
Thankfully, I had a big enough CF sheet, and could cut another two :
Next, I tried to file them down to shape... Easier said than done.
While the bowed-in square design looks great, it proved very difficult to get symmetrical circular edges.
As my inability to do so became more and more apparent, I decided to move on, and drill the holes for the arms. The idea being that they may serve as reference points to make the filing easier.
To get perfectly aligned holes, I used double-sided tape to hold the plates together, and taped a 1:1 printed pattern on top.
Worked like a charm
After that, I resume filing the center plates. Here's the result so far :
I'm still not 100% happy. They look quite uneven, so I'll spend more time trying to perfect their shape.
That's all I could do this week-end unfortunately. I hope I'll be able to work on it again this week. I'll update this thread at that time
- KISS 18A ESCs
- Naze32 Acro
Worked like a charm
