Help! Add weight or make it longer to get the right CG
ark
My latest build seems a little tail heavy and so to make the CG be in the right place on the wing I will either need to add weight to the nose or make the nose even longer so the battery is further forward. Does anyone have any advice on which would be better? Thanks!
I always make the nose longer.
Slide the power pod and battery forward and do a trial balance. When you know how much to add, make a cut around the fuse and add in the extra foam board and glue everything back together.
  • Like
Reactions: ark
AIRFORGE
Make It Fly!
What plane is it?
Before adding weight, can you do anything to make the tail lighter?
Can you move the wing back?
ark
What plane is it?
It's a simple stick pusher with FPV. There's not much to remove from the tail since the elevator servo is in the wing already. I can move the wing further back on the next one, but not this one since it's already glued, I was trying to keep the tail to wing distance the same as the Hangar Simple Stick it's based on. This one uses fiberglass tent poles, the next one will use some 5mm carbon fiber rods that are on (slow) order so that should be a lot lighter.
AIRFORGE
Make It Fly!
Nice design, man! (y)
Based on what I know now, I agree that extending the nose may be the best option, and adding weight to the nose is another option. I think simply adding weight would at least get you in the air for a "proof of concept" flight.
Again, nice design. Keep us posted, I'd like to see how it flies!
PsyBorg
Wake up! Time to fly!
Try peeling the paper off the tail. nearly 50% of foamboards weigh is in the paper. You can always be lighter in the tail then reseal the foam with minwax, white wood glue or paint.
