French
Construire Voler S'écraser Répéter
I've been flying with a Tactic TTX650, which I received for free. It's an SLT receiver that uses a wireless trainer feature. That means it doesn't come with a hard wired trainer port. Of course, you can buy a wireless SLT USB adapter for $120 if you want a copy of realflight too
After some quick searching, I came across this post on rcgroups that shows the PPM output on the transmitter.
So I ordered up some 3.5 mm mono jacks on Amazon and went to work.
I drilled a 15/64 hole in the back of the shell.
I found some wires already in a plug and soldered them onto the jack. Then a bit of heatshrink and two dabs of hot glue to keep it from twisting.
Perfect fit!
I added a 3.5mm male to make cable. Plugged into my computer's mic port. Fired up SmartPropoPlus and was able to start crashing on FPV Freerider Recharged!!!
Perfect fit!
