Fluburtur
Cardboard Boy
So, I was tired of not having a simulator cable for my radio and as it turns out the cable I ordered is only for the firmware update so I decided to hack a standard 3.5mm jack into the radio.
It was not difficult at all, the stock port is nice enough to have a PPM pin (no proprietary protocol bullcrap!)
I just had to drill a hole and solder the tip pin of the jack to the ppm pin and ground to ground, obviously.
This is how it looks
However the jack I used was crappy so I had to use another one and place it higher on the radio, just on the side of the antenna to have enough room.
I just tried it with DRL and it works well, now I don't have to walk 20 meters to my backyard to fly!
You can also probably use it as a trainer port.
